High Mileage oil
Royal Oak MI.
My civic has 170,000 miles and been on a steady diet of 5w20 Quaker state green bottle. Recently developed a small oil leak,or really a seep. I was thinking of switching the oil to a higher mileage type. Think I should stay brand loyal with quaker state and try there HM,or do you all recommend another choice? Thanks for your time everyone. Hope you all enjoy your weekend!
Quaker State High Mileage is fine, as is Pennzoil High Mileage, Mobil 1 High Mileage, Valvoline MaxLife High Mileage and any others. If you want to stay brand loyal, the Quaker State High Mileage will suit you just fine. Otherwise, just go with whatever is on sale.
The Quaker State will be just fine for your Civic. One opinion I read on here quite a bit is that if this is a valve cover gasket the better option is to replace. If we are talking a rear main seal or something that is involved, the the high mileage oils are a good interim fix.
Quaker State High Mileage 5w30 50% Quaker State High Mileage 5W-20,,,Might help, oil will be just a bit thicker.
I have used liqi-moly motor oil saver add. with good results fwiw.
with those miles maybe a full sump of Quaker State High Mileage 5w30 would be better.
Appears to be oil pan? Thanks for your input...I will grab some Quaker State High Mileage. Car runs great,no rust. I will try a few oci's of the HM before pulling the pan. Now you got me thinking...5w20 or 5w30? Been on 5w20 all its life so far?
If it's not burning or using any oil and is just a small leak, I'd use Quaker State High Mileage 5w20, usually available at Walmart.
