My wife '01 RX-300 AWD has a mild leak in the rear differential on the driver side shaft seal of the Rear Diff.
I have been using Mobil 1 75W90 LS the past several D&F's on the TC and Rear Diff since we have owned the RX new!
It was only weeping mildly when I changed the Rear Diff & TC a couple of weeks ago and now has developed into a very, very slow drip(Read Diff-driver side seal only). I'm sure that the new M1 is doing some cleaning as well and maybe even contributing to the seal leaking more. The TC is fine...No leaks what so ever!
Since there is High Mileage oils and High Mileage ATFs that swell seals and such, is there a gear lube for my application that is considered a High Mileage???
Or, should I wait and see if the leak(which now developed), slows down with the newely installed Mobil 1 75W90 LS???
Can I spray any brake cleaner or in that area to clean out the crud around the seal or is brake cleaner too strong???
Thanks,
CB
Thanks,
CB
