Right so recently i have won at a auction loads of gasoline powered equipment i have a 7hp 4kw honda clone generator with a bad piston (it has a crack in the crown) so no compression anyway it is a honda gx200 clone with where everything is the same as the gx200 but the piston is 70mm in diamiter instead of 68mm so i reaserched and reaserched to find where i can get this piston and found out the hf predator 212 has a 70mm piston as well
does anyone know the dinmentions of the hf predator 212 psiton is?
Mine is 70mm in diamiter
49mm in hight
wristpin is 17.9mm
49mm in hight
wristpin is 17.9mm
