Helper springs
Illinois
My minivan rear end with coil springs sags when towing my camper and loaded with gear. Does anyone have any experience with either the Timbren rubber helper springs, link here, or the Firestone airbag suspension
link here
for keeping my minivan level when towing? Is one better than the other? Is one more durable than the other? Do they help?
2010 Kia Sedona
I have the Firestone Airbags, and the difference between 5 psi and 100 psi in the bags is about 4.25 inches in rear lift. My leafs are tired, and I carry a couple hundred extra pounds than if the Van were empty. I put 10 to 15 psi on the passenger side bag, 15 to 25 psi driver's side to level it out. They really help minimise how much a tractor trailer pushes me around at highway speeds, and significantly reduce lean in turns. The higher the PSi the less lean.
Airbags must have at least 5 psi to prevent chafing, and will effect the ride somewhat depending on vehicle.
Timbrens, depending on application might not engage until the suspension is compressed a certain amount. So Unloaded it might ride exactly the same, where 5 psi in the bags might make a noticable difference, or not.
The Adjustability of the Airbags is the biggest bonus over Timbrens.
The biggest advantage of Timbrens is they are an easy install and forget system, no worrying about PSI changes, or bag puncture, or possible having to modify the exhaust slightly to keep it a few inches from the airbags.
There are other products like Shocks with coil over springs on them, and extra helper leafs which clamp on the leaf springs too.
Less palatable products in my opinion. I don't believe the shock towers/ mounts on most vehicles were designed to lift the vehicle weight, and you might not even have rear leafs to clamp a helper leaf to.
Note that adding Helpers does not increase the overall amount the vehicle can carry or tow, it just makes the rear sag less.
Consider adding a transmission cooler.
Thanks for the reply. I had helper leaf springs on my S10 pulling the same trailer and I really liked how they improved the the ride. But now I have the Sedona which has coil springs so that is why I am looking these.
I have AirLift (same as Firestone) helper bags installed inside the rear coils on my car. I love the ability to adjust the springs to suit the load. It sags bad with the civi springs and just about any load. Now I just pump them up the 35psi (max) and can carry up to door sticker payload with no sagging. I generally run 10-15psi unloaded because I like the rake it gives it.
