OVERKILL
$100 Site Donor 2021
I'm sure many on here have done spring replacements before. I've done quite a few, and they can be a ROYAL PITA. The ones on the Focus required a compressor and had to be tensioned "eye squint" level (where you think things are going to come apart) to get them in.
Fox Mustang ones are a REAL treat (the front ones).
So onto the 328i:
Both rear springs had a broken coil at the bottom, the right side broke higher up than the left side, and it was making noise. That's how we found it.
Ordered the springs from Bavauto (made in Germany
) and they were only $69/each.
Replacing them is a breeze
-Jack up car
-Pull wheel
-remove lower shock bolt
-stand on the hub to lower the control arm
-pull out spring
-Have a helper stand on the hub while you place the new spring.
-A nudging with a crowbar or prybar of some sort is necessary to get the bottom coil up over the rubber "nub cap" on the LCA assembly.
-Jack up the control arm to re-align it with the shock
-Re-install the shock bolt
-Replace wheel
-Lower vehicle
Both sides took less than an hour and I fixed the headlight auto-levelling switch while I was in there.
And another interesting note, I have not broken a single fastener on this car. That is despite the fact that it has seen at least 12 Canadian winters...... The 10mm nut on the headlight adjuster was pretty crusty and I figured it would break, but it came right off. The threads underneath it were still that grey coating that I've found on all the bolts on these cars
As much as I love my Ford's, I've broken enough rusted and rotten bolts and nuts on them (and the GM's and Chrysler vehicles I've worked on) to find this surprising, especially given that it is a few inches from the tire, and not protected by anything.
So onto the 328i:
-Jack up car
-Pull wheel
-pull out spring
-Replace wheel
-Lower vehicle
