Hi all. I have a 94 pontiac formula 5.7LT1 with 210,000 miles. It has developed a part throttle stumble with occasional backfire.WOT car will back fire and then pull hard to redline smoking the tires all the way even with knock retard pulling 8 or 9 degrees of timing. Data logging shows all sensors appear to be functioning properly including 02 sensors. ECU is callling for knock retard at all throttle settings even when knock count is not incrementing. No SES codes have been set. Opti is only 5 months old and I just replaced plugs, coil, coil wire, ICM to no avail. LTFT and STFT appear normal. I am thinking about changing out the original 02 sensors and fuel pump Just because they are due being 12yrs and 210k old, but hate just throwing parts at a problem. Could my timing belt have jumped a tooth ?? Any Ideas ????
