Help with changing coolant to replace thermostat (1995 Lexus ES300)
OE Toyota or Aisin(made by Tama) T-stat. Toyota red or Zerex/Peak Asian Red. Also, the T-stat housing is the notorious valley plate that loves to leak on the 3MZ-FE, after they switched to pink.
I’ve thought about it and there is a lot of coolant in the engine block. I’d try and remove the block cocks. 10mm 6 point socket, head lamp, several long extensions and some spray lube and I believe you would be fine.
Make sure you have the heater turned to maximum heat. That way the coolant in the heater can drain out.
Reminder, I tend to go to the extremes at times.
You may not find the block drains easy to get out. If they are hex then use a 6-pt socket.
I would drain the radiator and then pull the thermostat. If you loose some coolant just rinse with a garden hose.
The torque spec for the 1MZ-FE block drain bolts is 10 ft lbs so I would expect them to come out without a problem. Go for it. I use a piece of clear vinyl tubing on the block drains to avoid a mess. USE THE OEM thermostat.
But it's probably brass in a cast iron block.
Most block drains I have come across were NPT. Not sure I have seen torque specs for NPT before.
