I'll throw my 2 cents in. I would not do anything right now. Based on the AutoWeek article, I would just wait until VWs new policy comes out. It sounds like they will cover it if you have performed maintenance in accordance with their schedules. But if you start screwing around with solvents, they won't touch it.
Short story. A local car had a quicky lube place do an engine flush before changing the oil. 100 miles later, the engine locked up. Tear down revealed that the flush loosened up sludge, which clogged the oil screen, which burned up the engine. Instructions on the flushing solvent bottle said to remove oil pan after flush and clean out. This wasn't done.
And just out of curiosity, what oil did you use, what weight, and how often was it changed?
