Help me pick my next oil
Brittany 🇫🇷
Car is the Mercedes W202 C180 in my sig. Highway driving, no short trips, cold start temp is not a concern. Sometimes you just stare at your stash and can't decide. I plan to run it for 10k km (6k miles) again. Most popular vote wins. Total Quartz 9000 5W40, Total Quartz 7000 10W40, Shell HX7 10W40 (SN+), Shell HX5 15W40 (SN+), Valvoline 20W50 (reluctant to use it, probably diluted with something else).
Shell Hx5 15w40 all the way, if cold start is not a problem, you can go over 10k with it with highway driving. I'd change it every 15-20k
reason why 15w40 is because its a lot more shear resistant, a lot more durable too.
HX5 15w40 has a pour point of -45'c, cold starting will not be an issue ;)
I've got Mobil Formula P 0w30 in the workshop at the moment with a pour point of -36'c
  • It looks looks you can put anything except gravy and Chilli Con Carne in there to me ;)
    • Engine oil
      SAE 0W-30MB 229.1All temperatures
    • Engine oil
      SAE 0W-30MB 229.3All temperatures
    • Engine oil
      SAE 0W-30MB 229.5All temperatures
    • Engine oil
      SAE 0W-40MB 229.1All temperatures
    • Engine oil
      SAE 0W-40MB 229.3All temperatures
    • Engine oil
      SAE 0W-40MB 229.5All temperatures
    • Engine oil
      SAE 5w30MB 229.1All temperatures
    • Engine oil
      SAE 5w30MB 229.3All temperatures
    • Engine oil
      SAE 5w30MB 229.5All temperatures
    • Engine oil
      SAE 5W-40MB 229.1All temperatures
    • Engine oil
      SAE 5W-40MB 229.3All temperatures
    • Engine oil
      SAE 5W-40MB 229.5All temperatures
    • Engine oil
      SAE 5W-50MB 229.1All temperatures
    • Engine oil
      SAE 5W-50MB 229.3All temperatures
    • Engine oil
    • Engine oil
      SAE 10W-40MB 229.1Above -20 °C
    • Engine oil
      SAE 10W-40MB 229.3Above -20 °C
    • Engine oil
      SAE 10w30MB 229.1Above -20 °C
    • Engine oil
      SAE 10W-50MB 229.1Above -20 °C
    • Engine oil
      SAE 10W-60MB 229.1Above -20 °C
    • Engine oil
      SAE 15w40MB 229.1Above -15 °C
    • Engine oil
      SAE 15W-50MB 229.1Above -15 °C
    • Engine oil
      SAE 20W-40MB 229.1Above -5 °C
    • Engine oil
      SAE 20W-50MB 229.1Above -5 °C
Exactly, i can throw anything at it and it makes no difference at all haha.
As long as it has the required Mercedes-Benz approval. All of the ones listed have the same HT/HS requirement and I doubt the winter rating of the oil makes much difference there in France.
95% of the oils sold here have the MB 229.1 approval and above so i can basicaly pick anything i want.
Time to vote! Next oil change in the next days, here's what i have in my stash:
- Elf Evolution 900 5W30 (SL/CF, A5/B5, Ford WSS-M2C913-C)
- Elf Evolution 900 5W40 (SN/CF, A3/B4, MB229.5, A40...)
- Elf Evolution 700 10W40 (SN/CF, A3/B4, MB229.1...)
Elf Evolution is just Total Quartz with a different packaging.
I’d stick with one of the A3/B4 options. Occasionally when I’m in a similar quandary, I end up selecting a particular oil in my stash because I can’t use it in any other vehicle.
