I have the DV6DTED M which is the 92ps 8 valve version with EGR and catalyst no DPF/SCR
I sourced a lot of cheap HDEO Yacco brand oils locally and I want to know which would work best to provide the best wear protection
PS: running high sulfur fuel maybe around 2000 ppm
the temperature here rarely drops below -5 C and goes up to 45 C in the summer
the engine did 180k km now and it's 9 years old
i do ~ 80% city 20% highway + rarely short trips + couple of engine stop-start daily
Throughout the years I've filled Total 5w30 INEO ECS and for the last 6 oil changes I've filled it with Total 0W30 INEO First as per the official UK Total website recommendations
OCI is 10K km
For the last OCI, i noticed it lost around ~300ml of oil which it didn't use to do before and i think it did just in the last 3k of the OCI not sure though
the Yacco products are : ( from the cheapest to the most expensive relatively per litre )
TRANSPRO 40S
TRANSPRO 65S NewTech SAE 10W40 ( i can tell from the approvals that noack <= 11 | zinc/phosphorus <= 800 ppm | calcium <= 1500 ppm )
VX 500 10W40
LUBE GDI 10W30
VX 1000 FAP 5W40 ( almost 2x the price of TRANSPRO 40S 10W40 )
i also found Castrol Vecton 15w40 ck-4/E9 and and Total 9000 5w40 for a similar price as the TRANSPRO 40S
I mailed Yacco for more detailed information about the products and advice it's been almost 15 days with no reply
+ Unfortunately, I don't have the option to do UOA
Please help i would be very thankful
OCI is 10K km
TRANSPRO 40S
VX 500 10W40
LUBE GDI 10W30
