Jeffs2006EvoIX
- Joined
- Feb 28, 2010
- Messages
- 1,663
Originally Posted By: bluesubie
Mobil1 recommends their 0W-40 for street cars that see the track. Although I'm curious to see how Mobil 1 5w30 GF5 would hold up in a turbo. Just can't find any guinea pigs to do used oil analysis..
Subaru recently dropped the thicker viscosity recommendations from their manuals, but a lot of new WRX owner's are still running Rotell T6 5W-40. In one case, a guy went to the dealer for a misfire code. The dealer said the RT6 was causing the misfire (even though there were no changes to the engine), drained the Rotella, and charged the guy $100 for an oil change. Of course, his misfire returned.
If I ran 5w30, I think I would go with one that has an HTHS of 3.5 or higher. One option is Max Life Full Synthetic, which bourne mentioned above, but I've never seen it. Motul X-clean is another. And who says you're "required" to follow a "recommendation" anyway?
Well I have done used oil analysis on my previous Evo 9 using Mobil 1 Extended Performance 10w30 and they are up on the site somewhere. I will have o look for them. The Mobil 1 held up well. The only reason I switched to other oils were my needs changed. When I was running meth/water injection and pushing 430 at the wheels I was running 10w40 Royal Purple XPR which is formulated for use with water/meth. When I pulled the water/meth and switched back to 91 pump but chose some new bolt on mods I used the Redline 5w30 to suit those mods.
As for the use of what Mits recommends isn't really my issue. Its the fact that in some markets the same exact car with same exact engine gets 0w40 instead of 5w30 so it gave me a mmmmmm momment. I was thinking, that maybe just maybe the 0w40 Mobil 1 would be so similar to redline 5w30 that it would be worth a shot while saving a few bucks. Hope that makes sense? I just have no experience with any 0w oil or Mobil 1's 0w40. Is why I am here to inquire
Jeff
-Dennis
Jeff
-Dennis
