.... What scan tool are you using?
Hi, Trav, Tool is Invova 3130.
Okay I looked at it, check the wire with a DVOM it should have about 10K ohms per foot, compare it to a similar length wire also to double check. Move the wire around while testing it to see if the readings drop out.
Change the plug, its probably fouled now anyway..
I will pull the plug and take a look, also check the resistance on the wire.... To answer a question earlier on tail pipe, I don't know, but did not notice any blue or white puffs as I backed out right after it stopped misfiring. Normal cold start does not have either blue (oil) or white (coolant) smoke coming out from tail pipe.
In thinking of injectors, what brand do you guys recommend?
Man are you in luck! Go to Rock Auto and order 6 of the WVE/AIRTEX/WELLS 4G1422 for $16.34ea (I get $16.25 to clean them) I can tell you for a fact they are new Bosch injectors by the 0280 part number. Jump on these right now.
https://www.rockauto.com/en/catalog/mazda,2000,mpv,2.5l+v6,1359176,fuel+&+air,fuel+injector,6224
