- Joined
- Feb 15, 2022
- Messages
- 172
Can someone show me what this is used for?
Or one of those bit ratchets that are really 1/4" driveYou could put a 1/4"-drive, 1/4" socket on one end and use a hex to turn it, with a socket (of any size) on the other end. Might come in handy if you don't have a normal ratchet to turn it with.
My great little 15 dollar power Skil screwdriver, has a double male joiner that is great for a lot of different mini sockets and torx bits with female ends. Used every oil change for the under carriage cover.Or one of those bit ratchets that are really 1/4" drive
I bought a bag of tools at a pawnshopDid you buy the tools at auction or something
Wouldn't that be hex, not 1/4" square.My great little 15 dollar power Skil screwdriver, has a double male joiner that is great for a lot of different mini sockets and torx bits with female ends. Used every oil change for the under carriage cover.
I'll look nest time i am in the garage.Wouldn't that be hex, not 1/4" square.
To do what? I bet make up an odd length.I have to use an Allen slug into a normal 6 pt socket to make my "double female" adapter.
It’s a mystery. I don’t know what they are. It must be some kind of tool collaboration. It has no size so I got four pieces that I’ll never use in my shop.Those two are different. They are just extensions, have a female connection on one side.
One way or the other, all those knurls scream "manual driver". Possibly to gently drive nuts to hand tight for small nuts and bolts.
