I am trying to find the best way to check for air leaks that could cause high silicon or other high readings in UOA. ANY TIPS WOULD BE APPRECIATED!
I though about spraying the intake ducts, connections and the air intake manifold with starting fluid. My thinking is I should notice engine changes if it is pulling the starting fluid in. The starting fluid will not leave a mess. But I don’t know number one if it will work. Could it possible cause cause damage external or internal? Could some other spray be used? Well if nothing else some of you may get a little humor out of this. Any Tips or Suggestions WOULD BE APPRECIATED!
