My car - 1993 Mazda MX6 2.0L ~209,500 miles
Last test two years ago was fine. Today it failed for HIGH HC at idle. It was 1000-2000; pegged the meter @ 2000. CO was 0% @ idle too, which was weird. At 2500rpm it was close to the passing limit; could have gone either way.
About 3 weeks ago, I noticed a rougher idle and ocassional dip in the idle by 100-200 rpms. My idle has always been smooth and steady. I ran two tanks of Redline SI-1, no change. Changed the plugs (old ones had 7k miles only), no change. Disty cap/rotor and fuel filter were changed at 203k. Wires were done at 179k. Cleaned the IAC valve, no difference.
I tried pulling the wires from the plug and from the disty to try and locate a misfire. All cylinders made the same difference - drop in idle and rougher. Each plug lead had spark at the end. Air filter is fine. Distributor ("disty") is 1.5 years old.
I'm stumped. Next will be to check compression. I've always run syn @ 5k OCIs, so I think the engine should be fine internally. (I was going to start ARX on my next OCI, after smog)
Not sure if its a full misfire now. I don't know what else to check. Its OBD1, so it doesn't help. Runs great at all other rpms, the "miss" can be felt up to ~1500 - MPG is unchanged. Thanks for any tips or ideas.
