Originally Posted by Eddie
I'd use a standard radiator flush which is cheap at Walmart..Radiator flush is made for this type of issues.
Actually, it isn't. In normal operation, the coolant will never encounter oil. Thus nearly all off-the-shelf flushes are acidic mixes for cleaning up rust/corrosion/silicate buildup. These barely touch oil contamination, so other flush products (more specialized) are geared towards these specific circumstances where coolant is contaminated with oil. These products specifically aid in the emulsification of these oily products, which acids don't do. Fleet maintenance pros see these failures fairly commonly in big rigs, and the Cascade flush (for oil removal) is SOP for a lot of shops. For those who get a warm fuzzy from pre-packaged chems, Fleetguard has two cleaners: Fleetguard Restore for oil contamination, and Restore Plus for corrosion & scale.
Originally Posted by Chris142
We use purple power when this happens.
That would work. So would Simple Green. Both will etch aluminum, so easy does it.
