Heavy weight
probably RedLine.
API Service Class
SN/SM/SL/SG/CF
Viscosity Grade
SAE 5W30
Vis @ 100°C, cSt
10.6
Vis @ 40°C, cSt
62
Viscosity Index
162
CCS Viscosity, Poise, @*C
60@-30
Pour Point, °C
-45
Pour Point, °F
-49
Flash Point, °C
252
Flash Point, °F
486
NOACK Evaporation Loss,1hr @ 482°F (250°C), %
6
HTHS Vis, cP @150°C, ASTM D4741
3.8
Do you mean normal operating temps? Here are some numbers from manufacturers Product Data Sheets, which I don't guarantee as accurate or up to date, but you can verify them yourself:
Valvoline High Mileage Synthetic and Mobil 1 High Mileage are both 11.7 cSt@100c.
As far as non-high mileage synthetics Mobil 1 and Lucas Oil are 11 cSt@100c.
German Castrol (Edge), which is 0w30 not 5w30, is the thickest at 12.2.
(I believe 30 weights range from 9.3 to 12.4 so there could be something heavier.)
Originally Posted By: fauxchemist
is there a 5 or 10 thirty oil with a vis. of around 12.1cst@100c?
Amsoil european car 5w30 has a vis of 12.3 and HTHS of 3.7 a very heavy 30wt
Because i wanna find an oil that meets my requirements without being a frankenbrew
What are the (or your) requirements? What is the application, driving habits, desired OCI, manufacturer's specs?
I dont know what the factory fill is. Application is 2001 lancer evolution 75-100 miles a day highway
I had a 4g63 eclipse with a evo3 16g and supporting mods running 18psi for a couple years, i ran Mobil 1 10w30 in that car with no issues at all. any good synthetic 30wt or even Mobil 1 0w40 if your wanting a thicker oil should do excellent.
What I meant was, why do you have these requirements?
Castrol GTX High Mileage 5w30 11.99 at cst100 and HTHS of about 3.3, or the 10w30 version just over 12 and an HTHS of 3.5, both excellent synblends and scads cheaper than German Castrol.
Rather than looking for the thickest KV, you need to be looking at the HTHS.
A more "robust" oilmay have a pretty good HTHS, while still not the highest KV100
