Heavy oil Engines
Pennsylvania, U.S.A.
Hello everyone and can some people here tell me the history, facts and info on the heavy oil engines that large cargo ships and others use for main propulsion? Kinda interested to know some stuff about these monster engines.
thanks in advance
adam
Hornsby-Akroyd oil engineFrom Wikipedia, the free encyclopediaJump to: navigation, search
An example preserved at the museum of Lincolnshire life, Lincoln.The Hornsby-Akroyd oil engine was the first successful design of internal combustion engine using 'heavy oil' as a fuel. It was the first to use a separate vaporizing combustion chamber and is the forerunner of all hot-bulb engines.
Early internal combustion engines were quite successful running on gaseous and light petroleum fuels. However, due to the dangerous nature of gasoline and light petroleum fuel, legal restrictions were placed on their transportation and storage.[clarification needed] Heavier petroleum fuels, such as kerosene, were quite prevalent, as they were used for lighting. However, heavier oils posed specific problems when used in internal combustion engines.
Oil used for engine fuel must be turned to a vapor state and remain in that state during compression. Furthermore, the combustion of the fuel must be powerful, regular, and complete, to avoid deposits that will clog the valves and working parts of the engine.
Contents
1 Early oil engines
2 Herbert Akroyd Stuart
3 First production oil engine
4 See also
5 Notes
6 External links
[edit] Early oil enginesThe earliest mention of an oil engine was by Robert Street, in his English patent no. 1983 of 1794.[1] The earliest working engine was built by Julius Hock, of Vienna, in 1870.[2] Hock's was a non-compression engine, not unlike that of Étienne Lenoir.
Others made refinements to the oil engine; William Dent Priestman,[3] George Brayton and Emile Capitaine [4] are some of the more notable. However, it was Herbert Akroyd Stuart's design that was the most successful.
[edit] Herbert Akroyd Stuart
Diagram of early vaporizing oil engineAkroyd Stuart's first prototype engines were built in 1886. In 1890, in collaboration with Charles Richard Binney, he filed Patent 7146 for Richard Hornsby and Sons of Grantham, Lincolnshire, England. The patent was entitled entitled: "Improvements in Engines Operated by the Explosion of Mixtures of Combustible Vapour or Gas and Air".[5]
Stuart's oil engine design was simple, reliable and economical. It had a comparatively low compression ratio, so that the temperature of the air compressed in the combustion chamber at the end of the compression stroke was not high enough to initiate combustion. Combustion instead took place in a separated combustion chamber, the "vaporizer" (also called the "hot bulb") mounted on the cylinder head, into which fuel was sprayed. It was connected to the cylinder by a narrow passage and was heated either by the cylinder's coolant or by exhaust gases while running; an external flame such as a blowtorch was used for starting. Self-ignition occurred from contact between the fuel-air mixture and the hot walls of the vaporizer.[6]
The Stuart engine is of four cycle design. During the intake stroke, fresh air is inducted into the cylinder through a mechanically operated intake valve. Simultaneously, oil is injected into the vaporizer. The vapor of the oil is almost entirely confined to the vaporizer chamber. This cloud of hot oil vapor is too rich to support combustion. On the compression stroke of the piston, the fresh air is forced through the narrow neck and into the vaporizer. Just as compression is completed, the mixture is just right to support combustion and ignition occurs.
By contracting the bulb to a very narrow neck where it attached to the cylinder, a high degree of turbulence was set up as the ignited gases flashed through the neck into the cylinder, where combustion was completed. As the engine's load increased, so did the temperature of the bulb, causing the ignition period to advance; to counteract pre-ignition, water was dripped into the air intake.[7]
[edit] First production oil engine
Vaporizing Oil EngineAkroyd-Stuart's engines were built from June 26, 1891 by Richard Hornsby and Sons, a large manufacturer of steam engines and agricultural equipment, as the Hornsby Akroyd Patent Oil Engine under licence and were first sold commercially on July 8, 1892. It was the first internal combustion engine to use a pressurised fuel injection system.[8] The engine was hugely successful. During the period from 1891 through 1905, a total of 32,417 engines were produced.
[edit] See alsoHot bulb engine
[edit] Notes1.^ http://www.eng.cam.ac.uk/DesignOffice/projects/cecil/history.html
2.^ http://www.1911encyclopedia.org/Oil_Engine
3.^ http://www.ingenious.org.uk/See/?s=S1&ObjectID={4C5877E8-4092-3984-46C5-23B0972A8D45}&source=Search&target=SeeMedium
4.^ http://www.gasenginemagazine.com/complete-archive/4816/
5.^ "The Akroyd Oil Engine". Ray Hooley's - Ruston-Hornsby - Engine Pages. http://www.oldengine.org/members/ruston/History6.htm. Retrieved 2007-07-29.
6.^ McNeil, Ian (1990). An Encyclopaedia of the History of Technology. Taylor & Francis. pp. 310–311. ISBN 0415013062.
7.^ Wrangham, D.A. (1956). The Theory & Practice of Heat Engines. Cambridge University Press. p. 664.
8.^ Ransome-Wallis, Patrick (2001). Illustrated Encyclopedia of World Railway Locomotives. Courier Dover Publications. p. 27. ISBN 0486412474.
[edit] External linksRichard Hornsby oil engine
Retrieved from "http://en.wikipedia.org/wiki/Hornsby-Akroyd_oil_engine"
Categories: Stationary engines
Hidden categories: All pages needing cleanup | Wikipedia articles needing clarification from February 2009Personal tools
Log in / create accountNamespaces
ArticleDiscussionVariantsViews
ReadEditView historyActions
Search
Navigation
Main pageContentsFeatured contentCurrent eventsRandom articleDonate to WikipediaInteractionHelpAbout WikipediaCommunity portalRecent changesContact WikipediaToolboxWhat links hereRelated changesUpload fileSpecial pagesPermanent linkCite this page
Print/exportCreate a bookDownload as PDFPrintable versionThis page was last modified on 2 February 2011 at 15:52.
Text is available under the Creative Commons Attribution-ShareAlike License; additional terms may apply. See Terms of Use for details.
Wikipedia® is a registered trademark of the Wikimedia Foundation, Inc., a non-profit organization.
Contact us
Privacy policyAbout WikipediaDisclaimers Best matches for heavy oil engines
The Hornsby-Akroyd oil engine was the first successful design of internal... Jump to text »
