Heavier Weight for Older Engines?
Originally Posted by ka9mnx
Ok John. If the EP makes you feel better about the additional mileage then that is what you should use. I'm planning to go at least 10k on the vanilla. We'll see how that works out!
What vehicle?
My 2002 Honda Odyssey starting using a quart of oil per OCI at 80k miles using the called-for 0w20. I switched to 5w30 and it no longer uses oil. Gas mileage didn't seem to suffer, either.
My 2002 Odyssey is at 138k and isn't using any oil, but it's good to know I can switch to 5w30 if needed.
Also, was 0w-20 a typo or did they get spec'ed for 0w-20 later on? My manual (and oil cap) call for 5w-20.
It's not unheard of for Ford to back-spec cars for 5w30 that were originally specced for 5W-20.
I'm one of those thick oil(within reason) guys and have one car where I more or less run Maple Syrup(20W-50)...albeit that's the factory specified weight for it.
I bought my MKZ(Fusion by another name) from my dad with a bit over 30K on the clock, and had done the previous few oil changes on it for him. It started getting Mobil 1 5w30 at around 20K miles(BTW, he bought it from my grandfather with 17K on it, and my grandfather bought it new). It will tick over to 50K in the next few weeks, and I'm continuing to run 5w30 in it...in fact in my ownership I've stepped up to 10K OCIs so an oil change is on the table sooner rather than later.
I waited a bit longer in my old LS to jump on the thick oil bandwagon, and didn't go to 5w30 M1 until about 120K miles(it met an untimely demise, albeit with the drive train in perfect condition, at a bit over 150K miles). I had switched to using M1 "High Mileage" 5W-20 at around 80K, and at that point was also doing 10K OCIs on M1. I bought that car with 50K miles on it, and my first few OCIs were with Motorcraft 5W-20 at 5K. Had it not been for a blown passenger side airbag, I'd most likely have fixed the car and would still be driving it(aside from my fear of the driver airbag going, the blown pre-tensioner that made the driver belt only fit me, and the broken windshield the only thing keeping it from actually being drivable was a $20 cracked thermostat housing that would cause it to lose its coolant when the system was up to temperature and pressurized)-and likely still going strong now at 160-170K on 5w30. I sold it to someone who planned to fix it, although I haven't asked about his progress.
My friend has a 2002 Odyssey that has 5W30 on the oil fill cap but has 5W20 in the owner's manual. I think she's nearing 300,000 miles on it. According to the oil change sticker on the windshield,it has Castrol High Mileage 10W30 in it.
It really depends on the car and how well it was maintained as well as OEM specs. My old car lived happily on xxW-30 and used so little of it. OTOH, my current car I was able to get the consumption slowed down with with High Mileage oils. My parent's van is on 5w30 for all its life and at 135K, no signs of oil use.
I plan on switching a friend's Subaru to 5w30 or 0W-40 to try to reduce the oil it drinks. Yes, it did pass the oil use test they had out.
