I would say check the blower motor resistor. I don't know about a Sebring but blower motor resistor failure is a very common problem on Dodge Dakota's. Usually when the resistor fails you lose all but the high fan speed but I have heard of all speeds not working when the resistor is bad. Also check the wiring at the resistor plug connector, be sure nothing has gotten hot and melted together, and check the connector itself for corrosion and broken terminals.
On my truck the part costs less than $20.00 and is very easy to replace, it's right in the passenger's foot well mounted in the bottom of the HVAC housing. Buy a new resistor pack from the dealer, Dodge/Chrysler/Mopar did a redesign on the reistor packs a few years ago with much better and durable parts. You will see the difference when you compare the old part to the new one. I have heard that Mopar sold all their old stock of resistors to Napa.
