(2009 Pontiac Vibe GT)
Hi all. I had this problem before where a fuse blew along with a P0705 code. I replaced the fuse, and everything was fine for several months, if not a year. Today, the fuse blew again, but the replacement fuse blew as soon as I started the car (two fuses, both blew immediately.) The fuse in question is pictured.
In addition to the code, my airbag light came on, and the turn signals stopped working (maybe other random malfunctions, I'm not sure.) I've also pictured a part that may or may not be the problem, but I can't find out what it's called.
I recently replaced my radiator, which required a lot of banging around by the transmission, but that was about a month ago. I couldn't find any loose connections or anything out of place. Any ideas?
Thanks in advance,
Jonas
Thanks in advance,
Jonas
