It's that time of year again-- the time of year that we get a friendly reminder from our neighbor to set our thermostat to Emergency Heat because of the "bitter" cold weather we're having. I'm always at work when he stops by so I never have the chance to ask him why he wants to spend a boatload more money on heating his home than he needs to. My wife instead politely tells him, yes, thanks for letting us know.
How does this myth keep getting perpetuated? I've overheard folks at work tell others the same thing "better make sure you set your heat pump to emergency!" It's like the cool thing to do when it gets "super" cold. Sure, I realize heat pumps are less efficient in colder weather for obvious reasons, but it will never (at our temps) be as inefficient as electric grid heat-- most modern heat pumps have a COP of >1 down to -25F or so. Thermostats already use auxiliary electric heat (or gas/oil if equipped) to supplement the heat pump when it can't maintain the set temperature in a given amount of time. Let the system do its job.
Our heat pump does just fine down to low teens and single digits-- at or below those temps it'll run nearly 100% duty cycle (long as it can, with breaks for deicing/defrost cycle) but even at that rate it's still saving money vs reverting your whole system into an electric furnace (emergency heat setting).
Anyone else keep hearing this advice?
