Hear anything about a cruze diesel?
Michigan
So I hear that Chevy is coming out with a Cruze with a diesel engine. From what I hear the engine has been used in Europe for a while now. Anybody have the skinny on this?
Yes. It has been confirmed that there will be a diesel in the US Cruze for either the 2013 or 2014 MY. Iirc it will be the south korean 2.0L CRD diesel.
Sounds great but with diesel over .40 a gallon more than gas I don't see a reason to buy it. I love diesel engines, but it used to be the same price as 89 octane until the EPA got a hold of it.
^ It's going to depend on the fuel economy figures to see if it makes economic sense. That and the purchase price which will probably add a few thousand over the gas models.
My guess is ( like many other diesel optioned cars) you'll have to do a lot of driving for it to pay off. I still want one though
For a permanent traveler a diesel Cruze makes a lot of sense. Couriers, salesfolks, and others with super-long drives every day will gladly buy a reliable diesel car.
Do the math. If a diesel gets 25% better gas mileage on $3.60 fuel, then gas would have to be .90 per gallon cheaper. So it is still a savings of .50 per gallon. I know, diesel costs more up front, but the engine lasts longer and you don't have to change spark plugs either.
Originally Posted By: Cutehumor
will this cruze diesel get 60mpg?
I wouldnt hold my breath on that...
Here in KC diesel is 70¢ more than reg unleaded.
The engine MIGHT last longer, and have fewer costs.
Some diesel cars and trucks recently have had major engine trouble that costs far more to repair than gasoline engines.
You should read what happens to some VW diesels made recently, and some of the diesels used in Ford F-series trucks.
You should hear about some of the problems that have affected many Honda Hybrids.
Also if you need to replace that battery anytime after the warranty runs out, you will be spending a LOT of money. Many thousands of dollars most likely.
Originally Posted By: LS2JSTS
This is an article about a Detroit beat reporter driving a Euro spec Cruze around Europe...he returned 42 mpg in obviously very mixed use.
Cruze across Europe
After reading the article, that's actually a pretty impressive number. That mixed use included "12 hours of driving — much simply idling with heavy traffic and construction" and "reach[ing] 210 kph, 130 mph, on the Autobahn."
Given the stellar fuel economy of the gas MT Eco Cruze, I'm hoping the diesel gets 50+ mpg. Otherwise it doesn't seem like it'd make sense for GM to offer it.
It will get more than 50 mpg. That would be great advertising for GM so long as the engines hold up this time. Seems like it would be a great advantage for chrysler or some higher volume mini-van maker to have a diesel option.
GM already makes ads touting the "42 mpg Cruze", not noting it's the Eco MT version that gets those numbers. Based on my Eco MT averaging 44 mpg since I got it, if GM says a diesel Cruze will get 50+ mpg highway, I'd believe it.
The ads will go, "GM now has the two most efficient non-hybrid cars in America", with much creative license use.
Originally Posted By: HTSS_TR
One of the problems with Diesel is availability, not every gas station has diesel because of low demand.
That depends where you live. I defy you to find a gas station in Texas that does not have diesel....and usually at every pump not just one lane. Lotsa diesel trucks here friend.
