Originally Posted By: Fordiesel69
Originally Posted By: Brett Miller
The headlights on my 2001 Jeep have really turned yellow....purchased a Permatex restoration kit which involved hand-sanding and while they are better, it really didn't do the job. I found a 3M kit which uses a drill-mounted arbor and various abrasives. Has anyone tried the 3M kit or another kit with good results?
You have NOT sanded the UV layer off yet. If you did, it would be able to shine.
You need to do the following:
Westand with 800 grit for 10-15 minutes each. This will remoove the damaged uv layer.
Wetsand with 1000 unit 800 grit scrtches are gone (5 min)
Wetsand again with 1500.
Wetsand again with 2000.
Then using a 3-4 inch foam buffer pad on a rotary NOT ORBITAL buffer, buff with ultra light pressure. Let the rubbing compound and machine do the work. You want to use such light pressure you may have to do it twice. They will shine like brand new.
Check out my album: Starts at page 2.
http://good-times.webshots.com/album/563660539UGRKZg?start=12
I haven't used lower than 1500 grit personally, but I've never let mine get too bad either. PlastX from Meguiar's is also good for light cleaning and usually its what I would do after wet sanding as a final step before cleaning mine off with water.
the important thing when using the sandpaper is to keep it wet, otherwise you'll end up leaving more scratches, which I accidently did once.
