Cleaned up headlight from 2010 Silverado using 800,1200, and 2000 grit rotary sander, and then polishing compound.
Use a clay cleaner; can be found in most supermarkets and definitely online. It works wonders and very easy to useI tried the Turtle Wax Headlight Lens Restorer Kit (about $21) and I must say TW had their chemist's working overtime.
It is a multistep process with a 'clarifier' that uses aluminum oxide as the very mild abrasive as the first step.
Then a lubricant is used with two pads and four sides to remove the oxidation with each pad having two sides for subsequent steps. Then there is a sealer system for the last step.
My lenses were very oxidized and I must say it removed 75-80% of the oxidation and clarified the headlamps considerably. Plan on about 2 hours minimum of intense 'elbow'' grease.
The driver's side headlamp had the worst oxidation, but the interesting thing was that most oxidation on both lenses were located at the upper 1/4 quadrant of the lens.
Yea, I redid my headlights with the Cerakote stuff and they’re starting to haze again. I might go back to sylvania.Sylvania kit, hands down. I had used the Cerakote kit, and while very nice results, the lights got ****ted up again after about a year. I got the cheaper Sylvania kit with steps 1 and 3 only - the activator and the UV sealant only. I had my own wet sand paper. I also used more grades in between the ones that they provide/recommend in the full kit (2x price). My CR-V headlights came out better than new IMO. I keep them protected with some Adam's CS3 regularly.
Let us know how it goes, I am about to try the Cerakote after a polish.Yea, I redid my headlights with the Cerakote stuff and they’re starting to haze again. I might go back to sylvania.
i did mine with Sylvania - they became less clear after a year and a half for meYea, I redid my headlights with the Cerakote stuff and they’re starting to haze again. I might go back to sylvania.
Yup! UV is what caused the polycarbonate to haze over.I used multiple sand papers and then different compound/polish with my Porter Cable polisher I use for the cars. Used a smaller pad. When done I masked off and sprayed with UV resistant clearcoat.
One thing if you have a good clean newer lights or ones you fixed, Headlight protection film helps a lot as it adds UV protection but mostly keeps what you have from getting destroyed by the sand/rock chips that adds to it.
These are original, never garaged on a 230k+ '08 CRV. The headlight film was getting ugly and was glued on hard. PITA getting the glue off.
No before but the foggy is after wet sand.
View attachment 244619View attachment 244620
View attachment 244621View attachment 244622
And reference. 13 year old Sonata, 220k, sitting for many months not washed (engine went). I put the film on when it was new. The hazy you see is actually the small pits in the film from sand/rocks. Never garaged. they did get waxed when I did the car with whatever I was using.
Man you're doing way too much.Headlight restoration is the bane of my existence; I've done it something like 10 times and (even now going through the process), still cannot achieve good results.
From what my failures have gleaned thus far: A successful headlight restoration requires 4 parts to work successfully: 1. removal of the existing clearcoat, 2. successful removal of all underlying scratches in the plastic, 3. clean polish across the entire surface, 4. successful application of an appropriate clearcoat.
This gets into the realm of quite advanced finishing, and this is why almost every "kit" is useless garbage. They're trying to include an entire restoration shop in 1 small cheap box.
Right now I can only provide recommendations for steps1, 2 and maybe 4.
For step 1, use a random orbital sander with a relatively aggressive grit (like 220, or even lower) to remove the old clearcoat. The lower you go, the more work you will have for step 2.
For step 2, use wet sandpaper with water to step up the grits all the way to 5000. i.e. 220, 320, 400, 600, 1000, 1500, 2500, 2000, 3000, 4000, 5000. Wipe off with a shop towel, rag, or anything else, the dust between each step.
For step 4, I use eastwood's Exo-Armour, a siloxane based 2-part clearcoat. It seems currently unavailable, who knows why. Probably works too well so the government banned it.
I miss the old headlight regulations, because all of this **** is ********.
This is nearly exactly my headlight polishing routine, except that I skip the clearcoat part. My final l step is to polish the headlights with Nu Finish car polish.I have my own kit.
Bucket of hot water and a few blops dawn dish soap.
Wetsand with 600 until old clear is gone.
Westand with 800
Wetsamd with 1000
Wetsand with 1200
Wetsand with 1500
Wetsand with 2000.
Buff with foam cutting pad and rubbing compound.
Buff again with foam polishing pad and finishing compound (3d one)
Wipe with damp blue shop towel containing laquer thinner or acetone.
Wipe with a soaking wet shop towel of alcohol.
Apply a 2k clear coat of whatever brand you want.
This is permanent. 5 yrs or more.
The 10 th Gen Suburbans (2007-2014) have an unusually soft headlight cover. I tried a kit and the first grit cut into the plastic too far for the subsequent grits to clean it up. I may have to buy replacement headlights which are about $ 70 USD each.
