Originally Posted By: Quest
Headgasket related coolant leak can only get worse over time, not constant/better (*so long as you do not add sealer or similar).
If your coolant loss gets worse over time and pressure tests verify that then yesh, headgasket leak indeed. If not (stay constant), it's somewhere else so check all the coolant joints, hoses, etc.
How fast would a headgasket leak get worse,days,weeks ,month,
