Head gasket issue?
New York
I just bought a 2004 honda civic with the 1.7l vtec. I've been having issues lately where coolant keeps coming out the over flow tank from what seems is excessive pressure in the system. Then yesterday the car overheated. Is this a head gasket issue? How do I know for sure
When it's doing its thing loosen the radiator cap. If it gets worse the cap is good. If nothing happens the cap is bad.
Or you could just slap a new cap on there.
Sure sounds like one leaking between combustion and coolant. You can get a kit to check for exhaust gasses in the coolant.
I replaced the cap before it over heated. And I noticed today that after driving it for a while the upper radiator hose is hot and the lower is ice cold. Stuck thermostat?
Is the coolant bled? Air pockets can cause overflow sometimes.
+1 on the radiator cap.
Pull the spark plugs and look for a shiny 'steam cleaned' pistons
Compression test might show if you're leaking compression into coolant
Any oil in the coolant or vice versa? (look for chocolate milkshake)
One of these is a very useful tool to have around the garage
http://www.ebay.com/itm/Head-Gasket-Combustion-Leak-Test-Kit-/262252890841?hash=item3d0f7d8ad9:g:EWIAAOxyVaBSoxUv&item=262252890841&vxp=mtr
Having dealt with a bad head gasket and replacement on an 01 Civic at ~160k miles, AF bubbling out of the recovery tank is a main telltale sign of bad hg on the Civic. First thing that showed on the 01.
You can try testing with a combustion gas leak detector. But, I'd bet dollars to donuts the head gasket is shot.
How many miles does your Civic have ?
So many responses, so much misinformation...
A head gasket fails when there's oil in the coolant. What you're describing sounds more like coolant that needs to be changed, especially if you've just bought it and has an unknown service history. Coolant that has lost it's juice from time boils out and expands into the tank.
It's always good practice to change out all the fluids when you buy a used car..don't forget the brake fluid, too.
My buddy lost a piston to a hg failure with no oil in coolant visa versa. Thanks for forewarning about misinformation.
There's more than one mode of failure for a head gasket. It seals 3 different systems from each other. Combustion, coolant, and oil. Any could leak to the other depending on the failure. Each would produce different symptoms.
True that. And thus the prior recommendation for combustion gas leak tester for the AF.
And I can state for a fact that the AF in said 01 Civic with bad hg, the coolant was regularly maintained and up to date. It's still bubbled out of the recovery tank. No misinformation, a same generation Civic anecdotal experience with a bad head gasket.
