Head Gasket Fix
Ohio
I have a 1992 Mitsu Mirage with almost 150K....it has been leaking coolant and as I feared my mechanic told me it was the dreaded head gasket leak.
Is there any good fix, per this informed group, that may help extend the life of this car? The fix, $1000+ is way too much to be spending on this car at this time as the car not worth it... still it runs fine and I would like to get as much out of it as possible.
Any suggestions would be great.
Thanks,
Larry X
Is it pouring out, or just going up in unseen steam? I'd keep the puke tank full, and if the leaking is only occuring under pressure, run the cap at the first stop so it doesn't build to full pressure. Whatever is lost will draw back in from the puke tank.
I've driven my beaters over the years for many miles without "needed" head gasket or radiator repairs just by keeping the maximum operating pressure off the system. Also, make sure you don't have some obscure heater hose down there with a leak. Mitsu and Hyundai put hoses in the MOST unseen places.
Good luck!
You should be able to find coolant stop-leak products at an auto parts store. You can get sealer pellets too, might be worth dropping in a few. Not going to repair your gasket, but for a few bucks it might plug it up enough to be acceptable.
I had the same problem with my college car, 1978 Datsun B210. I just loosened the radiator cap and left it at that. Car worked fine for years. But, I was living in Guam and didn't have long mega commutes and it never got cold, hot yes, but not cold. The temperature guage on the car always stayed in the normal range.
Thanks to Vilan and Toocrazy. I will look for some pellets. Looking online I see there are some fixes that involve flushing and adding the liquid... like all those things I am sure that is hit or miss.
The fluid not overtly leaking, so the advise to keep the "puke" tank full is a good one. I think the fix way too much, so I am hoping I can drive it for a while with some bulk coolant purchases.
It does not seem to be mixing the oil and the coolant at this time, so I think I could be OK in the near term. These Mitsu cars really needed better gaskets.
Thanks,
Larry X
I was losing coolant in my '99 Grand Caravan with the 3.8. Dunno if it was a head gasket or intake gasket or something else, but it was definitely leaking into the motor as confirmed by a UOA. I tried the GM sealer pellets (no instructions on the package so I just crushed up all six pellets and dumped the powder in the rad). I was losing the entire contents of the overflow bottle over the space of about two monts. So far it's been a month and the coolant level in the overflow bottle has not noticeably dropped.
Larry, you're a funny guy!
It's 14 years old, man! I just traded my 92 Elantra, which was Mitsu to it's core. I just added a pint of coolant every couple of thousand miles to the puke tank. It never got into the oil, the plugs were all the same when I pulled em every thirty K, and never leaked. I have no idea where it was going.
Such is life with a 14 year old car.
Point taken toocrazy. I think I was thinking of the multitude of oil leaks that I have dealt with for many a year with this car. I am hoping I can just buy a couple of jugs of coolant every year and keep the puke tank full. I think that Mitsu hardly compares to honda/toyo for quality and I suspect they will be erased from global (car) competition in the future.
Thanks all for the wise advise. I want to keep this thing as long as possible, still runs ok and gets 30+ mph on my daily commute.
LX
I would recommend the Bar's brand of stop leak.
They have several forms.
I have the Bar's product in my windstar right now....and it has kept the timing cover and lower intake manifold leaks under control for going onto 2 years. My coolant usage was low, but it was getting into the oil.
I think the stop leak is good on the small leaks.
You will want to read up on what the total capacity of your cooling system is.
Then buy the correct amount of Bar's product for your capacity.
I have the same car. 92 mitsu mirage 4g15 4 speed auto. 132k miles. right now, fighting a very rough idle problem. btw, previous owner changed head gasket at 51k miles. I have and am still battling oil leaks too. I would start with fresh coolant, add the GM coolant tabs or the bar's leak golden seal tabs. change oil every 3k miles to keep the coolant contaimination at a minimum. I like you don't want to sink alot of money in this car to fix the idle with a shop. I'm going to have to fix it myself somehow. the resale is worthless
Cutehumor, the resale less than worthless so I think you are smart to drive it until the wheels come off. I am not losing that much coolant, so I suspect the head thing not am pressing problem. I do 3,000 OCI's anyway, I do not think any coolant in the oil, if so not as much.
I will keep my eye on the puke tank and keep on driving. My next car will something bigger as I have a kid on the way, the longer I can keep this going the better.
LC
Humor!
My 92 Elantra, a Mitsu, had the up and down idle problem early on, and eventually a part called an idle control motor fixed it.
But until that point, I horsed around with the idle-speed, and disconnected (one-by-one) various and sundry emissions hoses around the throttle looking for any component that ran off of vacuum that had an effect. I did find one connection under there that caused the up-and-down idling to stop, and that put the engine into a fast-idle when warmed up. I then corrected that with the idle-control screw. In the winter I turned the idle down a little, and summer, I cranked the idle up a little to allow for the air conditioning. Eventually, the dealer (at timing-belt change time) suggested I fix it with the idle-motor for $200 with labor about 2 years into a nine-year stint with the car. Naturally, I found an auto-reclaimation-recycling firm that had it a month after I fixed it for about 50.00, but there IS a fix for it.
What engine are you guys contending with on that thing? Mine was a 1.6 4 cylinder DOHC, it was used throughout the entire Dodge Colt lineup, and was installed in millions of Hyundais and unknown (to me) Mitsu models domestically imported and overseas for many, many years. It was a great runner that engine, but the car was beginning to fall apart in other ways after almost 1/2 million miles of loyal service.
Larry, I wasn't bustin chops at the top, just kidding, BTW. I know the dilema of balancing what's a worthwhile repair and what's worth chucking the car over. Mine finally went over the top. Have you consulted with anyone over whether auto RX might help out with the oil consumption? Folks have had good luck with tht stuff in all kinda of ways from what I've read. In the interim, maybe a heavy-weight Dino would help with the consumption. Folks seem to like the 15W-40 Rotella and DELO.
Good luck with it.
quote:
Originally posted by toocrazy2yoo:
Humor!
Toocrazy,
this is a 1.5 L 4 cylinder SOHC. I do have a topic on the idle problem (sorry to hijack your thread larry) pics of spark plugs/wires will disgust you 500k in a hyundai/mitsu??
Sorry, no, 1/4, 258K on the body, around 170K on the engine (first owner blew the timing belt). The half-million was a mistake. But the engine was fine, just everything else started going on it the last month or so, and then a really expensive-sounding noise started in the accessory-belt area. So I jettisoned it.
1.5 Litre, eh? This Accent GT has a 1.6 DOHC in it. I hope I get as good a level of service from this one.
I have indeed done the auto rx cycle (2 actually). I think it really did help the engine, it was amazing how much it helped the pick up. I am reluctant to do the really heavy oil, not sure why. I am doing 10-30 now, would that be thick enough?
Like I said, this thing has been blowing coolant for awhile so I think it is not an acute problem more like another chronic leak. The car runs fine, I am just going to do very short OCI and baby the thing as much as I can.
Thanks to all.
Larry X
