Originally Posted By: d00df00d
Better rotors won't help your bite. They will help heat tolerance, which shouldn't be an issue at all with your driving. Stick with good quality normal-style replacements (I love Brembo, but NAPA Premium will probably be good too).
Hawk HPS is a great pad, but only when hot. When cold, it's nothing special (in the dead of winter it's sometimes worse than OEM). If you want your brakes to clamp down hard anywhere, any time, the best popular alternative is usually Axxis Ultimate. It's not always quiet and it dusts like nothing I've ever seen, but it gets the job done in a big way, in just about any temperature.
If your pedal is spongy, look into stainless steel brake lines or even a newer set of OEM lines. Also, pop your hood, look at the brake master cylinder, and have a friend jam the brakes; if you see any flex where the BMC is bolted into the firewall, make sure all the bolts are tight and such.
Same opinion about Ultimate. It is the dustiest pad I've ever seen in my life but bite is strong to a point that I have to warn my friends before I let them drive.
