I did a cooler line flush on my truck over last weekend and added in a magnefine filter on the return line (due to mileage). While that in itself was pretty easy (see: didn't have fluid all over the place), refilling the AT has been a pain. Due to cooler line flushing, it's hard to know how much you really have flushed and I just kept flushing until the fluid looked good. I believe that was around 14 quarts total I used.
Point is, when I check the AT dipstick it always looks like I added too much fluid. I've warmed up the truck, went through all gears, and checked it again and it appears I may have added too much. I'm not sure if I should bother with opening up a line and pumping out some or will it be ok having an extra quart (I'm guessing) in the AT?
Suggestions?
Suggestions?
