Thanks Steve. I may try out the Synpower in the VW in my next oil change so that VW never has an excuse to void my warranty. I figured even if it's not as good as Mobil 0w-40 which is likely, it's not going to harm my engine for one oil change. I'll get it analyzed and see how it does.quote:
Originally posted by Steve_RI:
VeeDub, if you go to the www.oilanalysis.com forums, there's a post from early january regarding Synpower 5W-40 vs Mobil1 5-30 in a VW. It should be easy to find since posts on that site have slowed considerably.
I recognize your name from a lot of the oil discussions from Clubb5. I don't post on Clubb5, but I'm DaisyCutter on the VWVortex site. I hope your not shying away from the Mobil1 0W-40 based on some of the crap that's said on that board.Some people are currently testing that stuff out and dbrowne1's 5w30 analysis looked fine in a chipped 1.8T, so I wouldn't worry about your warranty using any Mobil1 product. If you run Synpower, get it analayzed so all the 1.8T users here can compare numbers. I'm going to be running Lubro-Moly 5W-40 shortly, so we can add that to the list.![]()
Actually that analysis was posted on the 4th gen mailing list on May 1st, so it's not that old. Although I'm sure it is for the last formulations of Mobil 1 anyways, since SuperSyn was not out at the time of his original test. The Valvoline could possibly be SL though.quote:
Originally posted by jjbula:
Patman,
I think I saw that analysis elsewhere. I recall it being 2 or 3 years old.
If that is the case, then both formulations have changed considerably. Tri to SS on M1 and PAO to Group III on the Synpower.
Cheers,
JJ
Originally posted by Red Baron Golf:
I just read this thread from oilanalysis.com Seems like Mobil 1 may not be the cat's *** afterall...
http://www.oilanalysis.com/ message_boards/message_details_by_list.asp?foldername=Mobil+1+5w%2D30+vs%2E+Valvoline+5w%2D40+results&messagenumber=1%20
Direct baseline comparisons between Mobil 1 Tri and SS and Valvoline SynPower are available on my analysis spreadsheet. Just e-mail me if you need a link.quote:
Originally posted by Patman:
The one problem I have with those results is that it's really missing a lot of data! As usual,
Blackstone leaves out TBN, nitration and oxidation. Plus a lot of wear metals are missing.
One thing that really stands out is that both of these oils have thinned out a lot, they are
pretty much 5w20s now. Just another reason why I don't like 5w30 in a hard driven car.
The copper levels are high, but since this is most likely an LS1 f-body oil analysis, that makes
sense since they always seem to show high copper numbers.
I don't necessarily agree with this, especially for "newbie" oil analysis people. Blackstone is the best comprehensive and personal effort analysis I have come across (yes, I'm taking the one available here into consideration). Oil Analyzers is one of the most comprehensive for raw numbers (TBN, Oxidation, Nitration, full elements), as you can get analysis kits with mail in containers for as low as $14.......Their comments category, though, is laughable. You would need a lot of experience from members here to help you interpret the results. Otherwise, Oil Analyzer's results can be confusing. Then, there's always the Amsoil conflict of interest conspiracy theories.....quote:
Originally posted by Chris A:
He posted that one year ago. At the time, he had driven 10,000 miles since he put the Mobil1 in. I'm pretty sure at that time, Mobil1 came only in 5w30, 10w30, and 15w50 so he could not use a xw40 Mobil1.
I have been an avid Mobil1 user since '96. I have never seen a 10w40 Mobil1 oil. I am the type to go to all kinds of stores looking at what they have and finding the best deal. All I've seen was the green, blue, and red cap'ed Mobil1. I'm not saying that they never made it, but it definately was not as easily available as the others.quote:
While that is true that Mobil did not have a 0w40 at that time, they did have a 10W40. I used to use it. Then I reread my owners manual and realized that I was supposed to use 10w30.
True, to have any conclusions that Synpower is better than Mobil1, you would need an apples to apples comparison, but as he said:quote:
Bottom line is that any comparison needs to be apples to apples. Who knows what how Mobil 1 10w40 would have done?
