This happened after the car developed a chirping belt noise which I was pretty sure was caused by idler pulley/tensioner/serpentine belt - and a trip to the dealership confirmed it...
well KRAAAAAP !!!
STORY:
so....I went to the dealership to have the new belt, tensioner and pulley installed - and while i am there I remember this OTHER whining noise around 2000 rpm noise that has been bothering me for a while...and thought, well might as well get that checked out - so a tech drives with me, and i reproduce the noise, and he's not tally sure but thinks it might be related to the pulley/belt we're going to replace ... he also thinks it could be the heat shield loose...(which I also thought)
so we drive back to the shop and suddenly we here a THUD !!! and see a pulley rolling down the road - of course we assumed it was the idler pulley finally coming off etc. and get to the dealership safely - drive was about 3 min. AFTER the thing came off...
they go to replace the pulley, belt etc and come back and tell me it was NOT the idler pulley that came off but the CRANKSHAFT DAMPNER PULLEY !!! (this is the same as harmonic balancer, right?)
now they think THAT was that OTHER whiny noise we heard, apart from the chirping Idler pulley.
So, they don't have the Crankshaft Dampner pulley in stock - will get it on Monday..
they also told me that the Carnkshaft d. pulley is actually a double pulley that's sandwiched betw. some rubber surround and that dry rotting of the rubber may have damaged it...and THAT in turn probably made the idler pulley go bad.
ANNOYING !!!
I hope the Crankshaft D. Pulley (Harmonic balancer) being bad for some time didn't cause any damage to the crankshaft/engine... That other "whiny" noise had been around for about an year...
according to this, the harmonic balancer going bad CAN cause damage to crankshaft..
http://en.wikipedia.org/wiki/Harmonic_balancer
Quote:
...Over time, the energy dissipating (rubber/clutch/fluid) element (of the harmonic balancer) can deteriorate from age, heat, cold, or exposure to oil or chemicals. Unless rebuilt or replaced, this can cause the crankshaft to develop cracks, resulting in crankshaft failure....
well KRAAAAAP !!!
STORY:
ANNOYING !!!
