Originally Posted By: emg
Bad chips can be worked around, though. The first SSD I used many years ago was built from a complete RAM chip wafer, and they wired up all the good chips and ignored the bad ones. It had zero data retention because all the data was lost if the power went out
I believe some modern SSD manufacturers do something similar, by installing more flash than they need and testing to see which blocks are good and which are bad, then only using the good ones.
We shipped about 200 enterprise SSDs to customers in the last year and have only had one fail so far (sudden death, so probably a firmware bug). At home, I upgrade the SSD in my laptop to a new one of double the size every couple of years, then use it to replace the SSD in my Windows desktop, and use that one to replace the SSD in my Linux desktop (which has no essential files). Haven't had any problems so far, though this 1TB Kingston is the first non-Intel SSD I've used.
Back more on topic, I've never had problems with laptop HDDs other than the Toshiba drive that came in the last laptop, which failed a couple of weeks after the warranty expired. But, even though there was a rapidly-increasing number of bad blocks, I was still able to get all the data off it.
