Harbor Freight AC manifold gauge set
I've used my AutoZone set for a few years, and done dozens of co-workers' cars.
Just had to replace some of the o-rings, but otherwise seems fine. Not for professional use, but fine for occasional use.
wow.. I feel lucky to actually have an A/C Machine in my garage lol, sometimes I am spoiled by my tools... Haven't used an old school manifold like that forever, but the Robinair for $50 looks pretty good
The Harbor Freight manifold gauge set has, on the center connection where you connect the yellow hose, two fittings. One has a schrader valve in it, the other doesn't. What is the purpose of the schrader valve? Why are there two fittings there?
Is this so you can have both a vacuum pump and a can of R134a connected at the same time?
You can hook up a vacuum purge deice to the gauge set.
Don't let oil get in!
That Robinaire is at an outstanding price!
Consider going without a few lunches and getting that one recommended by TRAV.
That said, for occasional use the low buck one will do just fine.
Originally Posted By: bullwinkle
I have one, be CAREFUL not to bump the access fittings on anything-they are brittle & will snap off! Other than that they work fine.
HF updated the materials and they are much more durable now.
I have a set and they work fine. I paid $45 for mine though, as I had purchased them off eBay (not knowing they were HF).
Originally Posted By: Trav
IMHO for $20 more i would get these.Absolute pro quality tool at a lower than DIY price.
http://www.usatoolwarehouse.com/usatoolwarehouse/ROB-48510.html
That just makes me angry. I wish I had seen this several weeks ago.
Critic get the Robinair and sell yours on eBay. These are excellent gauges and well worth every penny.
With a hose connected, it can be frustrating to measure charge out of a can with a scale.
The can contents are a help - until the last one is needed with a partial fill. Even then, we can guestimate. With gauges and a thermometer, even better!
