What does everyone run for gun grease? I am currently testing out some Lucas Oil Extreme Duty Gun Grease, but in the past I was an oil only guy. Any merit to "gun grease" vs a tub of wheel bearing grease?
This is for slides on pistols and any other high friction areas. Preferably would be NLGI 1 or lower so it wouldn’t be too thick in the cold tempsmacnaught
they go on sale on the manufacturer website occasionally
https://www.amazon.com/Macnaught-cartridge-Connection-high-pressure-connection/dp/B07FNCMLTB
Grease depends on application.. no reason to bulk fill for most people
IMO tubes work great.
whoops thought he was talking about grease for a grease gun.. didnt see the forum subsection.This is for slides on pistols and any other high friction areas. Preferably would be NLGI 1 or lower so it wouldn’t be too thick in the cold temps
Pistol rails and AR boltsDepends on the application. What are you greasing?
TW25B is good for light applications. Mobil 1 Red grease for Garands.
TW25B keeps the Ma Deuce running...Depends on the application. What are you greasing?
I wouldn’t go any heavier than TW-25B. I have tried grease on some semi-autos, but while it felt smooth, it slowed the slide somewhat and could cause problems. Wilson Combat makes a very thick oil (they call it grease, but it is liquid) that is about perfect for AR bolts, though, as I have said before, most guns aren’t picky…Pistol rails and AR bolts
Edit: changed slides to rails. You know what I meant lol
I'd like to see a properly blended HPL Gun Oil with the viscosity of that goo.Mix Mobil 1 Synthetic Red Grease with Mobil 1 5W30 into a honey like mixture (thinner than grease / thicker than oil).
