Originally Posted By: CATERHAM
These are the spec's for the Cdn version of Mobil 1 Advanced Fuel Economy 0W-20:
MRV 10,400cP
VI 170
HTHSV 2.6cP
Does this oil appear to be different than the US version? Yes.
Is there any difference in the two formulations according to Mobil? No, it is just normal batch variation.
I don't buy that two PDS's with VI, MRV and HTHS all being different are all just "batch variations". If the oils were the same, they'd have the same Product Data Sheets. But they don't. So either the Canadian PDS is wrong (possible) or we are getting two different oils (less likely).
Quote:
The only reason I point this out is the MRV difference between the two Mobil 1 versions is a 1,200cP which may appear significant but is actually an insignificant at that temperature. In fact a temperature variation of a fraction of a degree can affect the viscosity of an oil that much at those extremely cold temp's.
Given the thread that this first appeared in (and you cited the CDN PDS back then) was started by you and was boldly pointing out that the ENEOS oil had
SUPERIOR MRV to the Mobil 1 0w-20 lubricant, why was it relevant then, and not relevant now? I mean then you were arguing that the 770cP difference between the CDN Mobil 1 0w-20 and the ENOS Sustina 0w-20 was significant. But we are to believe that the 1,200cP difference between the two Mobil 1 PDS's is "insignificant" and that if we use the US Mobil 1 0w-20 PDS as our reference, that it is also insignificant
which is it? It seems that this cold temp thing is an argument of convenience. Used to bolster your point when it favours your high VI argument and dismissed as "insigificant" when it doesn't.
Quote:
So based on the MRV spec's alone, Sustina is 730cP lighter than Cdn Mobil 1 and 430cP heavier than US Mobil 1 or lighter than an average of the two Mobil 1 oils. But for the sake of argument let just say Mobil 1 ans Sustina have the same MRV performance.
But you just said the 1,200cP difference between the two Mobil 1 grades was "insignificant", yet now we are being told that if we average the two Mobil PDS's and compare it to Sustina, that the 170cP difference between the two (in favour of Sustina)
IS relevant because it "makes them equal for the sake of argument"
What's this double-talk about sir?
Quote:
As for your conclusion that "at some point below 0 Mobil 1 passes VI-ZILLA in terms of thinness" you're wrong. At 0C Sustina is 34% lighter than Mobil 1 0W-20 and will remain lighter all the way down to -40 degrees at which point there virtually no difference.
Hold on a second, so you are saying that if I look at the two figures I quoted above, the 9,200cP and the 9,630cP, and we KNOW that at higher temps, the Mobil 1 0w-20 is heavier, but that the crossover I'm seeing here is all in my imagination? Is this because of this magically irrelevant 1,200cP again?
We don't have the CCS value for the Mobil 1 0w-20, so we don't know how close they are (or whether the Mobil 1 is, like it is at -40C, thinner).
Quote:
As for their HTHS viscosity spec's you're referencing the US Mobil 1 0W-20 (HTHSV 2.7cP), so I guess purchasers of the Cdn Mobil 1 0W-20 (HTHSV 2.6cP) don't have the same protection?
Where did I say
ANYTHING about protection? I said it (the US version of Mobil 1 0w-20) was still heavier at 150C. This was because part of your posit here is that the "uber VI" also means the oil thins less at temps beyond the two points used to calculate it. So I simply pointed out that the "much lower" VI Mobil 1 0w-20 is
still heavier at 150C than the ENEOS lubricant. So if there's some "high VI/high temp" (HVHT, hey, I've made a new acronym!!) crossover here, it hasn't yet occurred at 150C.
Quote:
The reality according to Mobil is that there is no difference between the two oils.
Unless you spoke to an actual Engineer at Mobil, I'd be careful in drawing a concrete conclusion here. We've had reps from Mobil say all kinds of neat things about their products, many of which we know to be patently false. I wouldn't be surprised if this was the case here just to placate you and get you off the phone.
OVERKILL. no offence but you haven't added anything factual to the discussion here.
The bottom line is that there is no significant difference in extreme cold performance based on the MRV spec's between Mobil 1 0W-20 and Sustina.
And contrary to what you said about Sustina being heavier than Mobil 1 below 0 degrees that clearly is no the case. Sustina is lighter at all temp's between 150C and -40C.
I should also point out that unlike yourself I have actually used both these oils not to mention a lot of other 0W-20 and 5W-20 oils. Without question Sustina 0W-20 is the lightest API oil you can buy on start-up and at normal operating temp's based actual oil pressure values. It is lighter than TGMO 0W-20 (VI 214), which which is lighter than the Idemitsu made Honda 0W-20 (200 VI) which is considerably lighter than Mobil 1 0W-20 (170-173 VI).
Again not just on start-up where the differences are most dramatic but also at normal operating temp's.
