Originally Posted By: Sayjac
As for louver openings, not going to speculate. Not wanting to feed the louver phobia. Will say though, some years ago when Champ(now Rank/Fram) was having the issue with some louver stampings not all open, they said flow was still adequate. Whether one believes/believed them up to the individual. Just reporting what they said.
I remember those photos ... looked similar to those posted by car51 at the top of the thread. All I know is that many photos seen of louvered center tubes shows the slits opened up a pretty good amount - like around 1~2 mm. But seeing slits that are no more opened than the thickness of a sheet of paper (0.010") makes me leery. IMO, they need to be opened a fair amount to ensure the total flow area is as least as large as the total flow area of the base plate holes.
One could do a calculation of X number of slits times Y flow area on each slit. If a slit is only opened 0.010" x 0.100" wide (assumed dimensions), then that's only 0.001 sq-in per slit. If there were 400 slits then that comes out to only 0.40 sq-in, which is way less than what the total area of the base plate holes would be on any typical filter.
If those 400 slits were opened up 2 mm (0.080"), then the total flow area would be 0.080" x 0.100" x 400 slits = 3.20 sq-in. Huge difference.
