I need advice choosing between the new Mobil 1 0W-30 with the green cap and PP 5W-30.
I have a Toyota 4GR-FSE direct injection gas 2.5L V6. I am currently running Amsoil SSO 0W-30, which now costs more than I wish to spend. I know to get your money out of that oil, you need to do extended drain intervals using the Amsoil Ea filter. One issue with that is that Amsoil does not make an Ea oil filter for my engine AND I intend to do the oil changes per the maintenence requirments until I am out of warranty, which is every 5K miles.
There is plenty of info on the PP 5W-30, and it is good and bad, but mostly good. The consumption issue some folks have and the debate over cleaning are the bad, but the solid wear numbers and price point are the good. I could not find any UOA on the Mobil 1 0W-30, as it is a new product. I had used M1 5W-30EP for 5K, and found that I had higher iron than I was comfortable with. However, that is a different formulation AND that oil was installed when the engine had only 10K on the clock.
I am leaning toward the PP 5W-30. Any thoughts?
Thanks
Mike
Thanks
Mike
