I have a straight shaft Craftsman weedwhacker that is 6 years old and used hard. Lately, I noticed the gear housing gets hot after an hour or two of use. I can still touch the housing but, it is fairly hot. Youtube videos advise you to remove the plug in the gear housing and pump in generic grease from a grease gun until the excess oozes out around the seal.
Does regular wheel bearing grease work for this application? What about compatibility with the factory grease?
I keep a grease gun filled with Lucas Red N Tacky wheel bearing grease for my trailer hubs. Will this work or do I need SPECIAL UNICORN TEARS WEEDWHACKER GREASE?
Thank you in advance for any advice and dealing with my mechanical OCD and analysis paralysis
