I have an Alemite A500 Grease gun, http://www.amazon.com/Alemite-500-Develops-Delivery-Cartridge/dp/B009K52WNY
I use 24oz cartridges, it has worked well the last 25 years
until today!
To change a cartridge I will pull the piston down from the bottom the gun body. Lock it down.
unscrew the pump. remove the old cartridge. put in a new cartridge. open it with the Ring Pull.
screw the pump back on.
Then release the piston rod, and push it back into the gun body.
Today, no matter how I tried, the piston won't go back in.
That is, until I thoughtlessly unscrewed the pump, then it shot out a whole tube of grease on the garage floor
until today!
