Alrighty guys and gals, I am in need of some help.
I have a 2001 Pont. Grand Prix GTP. I have posted a couple oil analysis for it on here but dont have the links right now.
At any rate, I have a cooling issue. As of late, particularly with it warming up I have noticed that the coolant temps. gradually and somewhat slowly rise on me as I am driving. I have a drilled 180* T-stat in it. A few months ago I had a 180* Motor-Rad thermostat in it, designed to lock open in the event of an over temp situation. Well it locked open on me though my temps never went above 190 or so.
I thought it was just an isolated event and perhaps the t-stat was just defective. As a pre-caution though I went ahead and replaced the t-stat and the coolant sensor.
All was fine, but I noticed that my temp. reading was just a line or two above the 180 mark now where as before it was a tick below it. However it remained stead and even in city driving it would never go near 210. I thought that the higer indication was the result of the new coolant sensor and left it at that.
As it warmed up I noticed that even at highway speeds (70 - 80 mph) the temps would slowly rise up and as I got in the city it would progress up to 210 and sometimes a little beyond though it never overheated. The fans were coming on and the thermostat was working as it should.
After my last oil analysis, though no coolant was detected, the high sodium levels had me concerned. So I started looking for trouble. I found that the thermostat gasket was leaking a little but the bigger issue was that the throttel body gasket leaking and had escaped my attention. I replaced that, the PCV, the radiator cap and then the t-stat and the gasket.
The coolant was looking a little off in color so I made plans to flush it. Well this weekend I went out to flush it and pulled the drain plug and got nothing. No coolant was draining out though I could clearly see that the radiator was full. I also know that coolant was flowing because I could open up the bleeder valve and coolant would flow out nicely.
I shoved a coat hanger up the drain port and shockingly enough I was getting some sediment out of there. Almost like beach sand which I learned is a result of Dex-Cool.
I couldnt get the system drained so I took it to a shop and had them flush the system. I can pull the drain plug now and the coolant flows out some now, but by no means as it should. So Im pretty convinced that there is some build up in the radiator, but am at a loss as to how to successfully get it all out of there.
The guy that did my flush said he checked flow through the radiator and the engine and all was good, but he too on the test drive, noticed the engine was not cooling off as it should. Its not overheating yet, but it isnt as hot here yet either as it is going to get.
So I need some suggestions on how to get this crap outta the radiator. Im kind of ticked and even more set against Dex-Cool more than ever. The shop put in green coolant. So any ideas you guys have would be appreciated. If I have to buy a radiator then Im going to get an oversized one, but I want to make that the absolutely last resort if possible.
The person that did the flush at the shop told me to bring the car by when I could and he would take a look at it with an infrared gun to see if he could detect any sediment build up from temp. readings. I hope to be able to do this tomorrow.
Thanks in advance for your help and input.
