These things are two bucks on ebay! Here's my review.
-- It does something resembling working, based on what I know about my vehicles. It has LEDs in green for zero percent, amber for 1 & 2 percent, and red for 3 and 4+ percent, labelled "bad."
-- 91 F150, did rear brake lines, bled, but didn't suck the MC dry beforehand. Fluid inside is dark. The amber "one-percent" LED flickers.
-- My vat of used brake fluid shows 2%.
-- My 4.5 year old Prius shows 0%.
As for use of the tool, it gives its best reading when you really stab the "fork" half an inch into the fluid. Bring a rag, it gets drippy. The LEDs are not optically shielded from each other within the guts of the thing, so the light transfers from "lit" to "unlit" fairly readily, making it less elegant to read.
Is it calibrated? Who knows, I would say it strays towards false negatives if you're supposed to change fluid every two years. Is it effective? Likely, if it tells you to change it, you really probably should. Is it worth the two bucks? IMO, yes!
I "could" get a calibrated beaker, some new fluid, and mix in some measured amounts of water for a definitive test... haven't yet though.
