Cheap brake fluid tester working properly?
Denmark, Europe
Hi,
I bought this tester on Ebay from China:
http://www.amazon.com/Brake-Fluid-Tester...ke+fluid+tester
As you can see from the reviews, people are extremely satisfied with the tester.
I made a test in a bucket of water and it rapidly showed +4% water as it should. But then I tested some old brake fluid which has been on the shelf for 4 years. 4 years ago the container was opened and the plastic screw lid (with no seal) was put on again. It has been resting like this in a shed experiencing summers and cold winters and relative moistures going above 95%.
But my tester shows less than 1% water in the fluid. Which means the fluid should be OK. But can I trust the tester?
PS: I also tried the tester with the brake fluid in my cars brake fluid reservoir and again it showed less than 1%. But I do not know when it was changed the last time because I bought the car 6 months ago (used car).
Lucas
In principle, should be easy enough to test.
Buy some fresh brake fluid (which might be date-coded?).
Test a sample, then spike it with steadily increasing known percentages of water to produce a calibration curve.
That's likely to be more specifically informative than anything anyone on here can tell you about your brake fluid tester.
I have one of those testers.
How reliable is the accuracy ? I don't know.
I tried it a couple times and now it sits in the basement.
I change my brake fluid every 2 years. So no matter what the Tester would show, I should be good.
I thought it was an interesting purchase and may just use mine for reference or to show a family member how bad their (neglected) fluid is.
Read the instructions. It says:
Dip the test probes into the brake fluid up to the plastic rim of the device.
Check for Repeatability by how far you insert the probe.
This is where I was getting inconsistent readings.
ive only used strips. It was supplied to me by BG products, i think they were rigged a little since it can help BG sell their brake flush. But what do i know.
Honestly now... i dont care too much. I've seen fluid look like used oil in cars from early 90s, the brakes all work and i wouldn't suggest them do a brake flush. My personal cars, i bleed a little every brake job and i'm not thinking twice.
Maybe your test of 100% water was too much water for the tester, LOL
