Good way to load test battery?
Oahu, Hawaii
According to Deka's PDF on AGM batteries, a way to load test a battery for voltage drop is to use a load tester and set the load to half the CCA of the battery. Less than 9.8v means the battery is damaged. A lot of the handheld carbon pile testers only go up to 130A and those smaller ones that shoot a pulse through the battery to determine CCA and stuff.
I tried a crude way to load test a battery. Hooked up a multimeter to battery, disabled fuel pump and held the key in the start position for 15 seconds. Voltage drop was 11.5V. 1.5Kw starter / 12 volts means its drawing 125 amps. Not really a heavy load but should I put a more heavy load to get accurate voltage drop measurements?
Vehicle tested 02 Chevy Silverado 5.3L, stock starter, Deka Intimidator AGM battery rated at 775 CCA/120 RC
I have one of these battery testers, crude but effective:
Carbon pile is the standard. I like to know battery impedance specifically, as then you can calculate voltage drop under any sort of conditions.
IMO though, cranking amps dont correlate well to the starter draw. I like to watch the battery voltage under cranking cold, with as many loads as I can have, on. I think this is a fairly practical way to see if the battery is keeping up.
Assuming you do not mind taking the time to charge up the battery, then the carbon pile tester is best. But a place that sells batteries and just wants a quick test, so they use a Midtronics.
