I recently installed the SynchroGlide from Specialty Formulations in my 2003 Honda Civic Si. I had been using Royal Purple Synchromax prior to that.
The RP that I drained looked pretty good (about 12,000 miles), but I couldn't believe how much thinner it was than the SynchroGlide that I was putting in. I have put about 300 miles on the fluid now. I noticed a slight increase in notchiness when cold and a slight decrease in notchiness when warm. I'm sure that as the summer gets hotter, the SF fluid will shift better and better than the RP did.
** Both fluids were TONS better than the Honda MTF that I changed after only 5,000 miles.
All of the Honda crowd loves the GM Sychromesh Friction Modified fluid. I was going to get it, but decided to give SF a try since it's fully synthetic and won't need to be replaced as often.
Here are some viscosities that I found:
Honda MTF - 11.26cSt @100C
Redline MT-90 - 14.3
Redline MTF - 11.2
RP Synchromax - 7.7
GM Synchromesh - 9.08
SF SynchroGlide - 9.5
SF MTL-P - 12.5
I'm glad that I went with their SynchroGlide instead of their MTL-P. It would have been way too thick and would probably have shifted pretty poorly like one of the reviewers mentioned on this site.
The newer Hondas really seem to like thin MTF and I'd recommend the SF SynchroGlide as a great shifting fluid that should also provide very good protection.
Redline MTF - 11.2
RP Synchromax - 7.7
SF MTL-P - 12.5
