Ryan,.
For new I would look at Ibanez or Ovation. But I would also look at used Taylors, though for that price it would be hard to find one.
Note, Ovation guitars do not requite you to wory about humidity because they are not wood. If the guitar is wood use the following information.
If you ever find a wood guitar you like I would highly suggest that you go to radio shack and purchase a digital humidistat. These units also have temperature reading, but humidity reading is why you need it. There are low cost models starting at about $20 but the model I prefer uses a radio link and cost $60/ on sale it goes for $50. This unit comes with one transmitter unit. Mount the sensor in the case below the head if the guitar is not a cutaway. If it is a cutaway mount it in the cutaway section of the case. Use Amazing Goop glue in the small red and white tube to glue the sensor or clip that holds it, to the felt in the guitar case. Let it air out for at least a day before putting the guitar in afterwards so the fumes from the glue do not damage the finish of the guitar.
The wood of a guitar will give off or absorb moisture depending on if the ambient air has more or less moisture than the guitar has been exposed to on average in the past. This will cause the wood to expand or shrink.
If the neck and top get too dry due to exposure to air that is too dry, the top will loose some of its moisture, and the curve and and height of the top will fall. This will cause the strings to get too close to the frets and the strings will buzz.
If the top and neck are exposed to air with too much humidity they will absorb moisture, and the bow of the top will increase. This will cause the strings to get too high to be comfortable to play.
Most good guitars that have a nice low action on the neck can only keep that close nice action if the owner keeps the humidity inside the case within a very narrow range of humidity. With time you will learn that if the humidity in the case is above a certain number the strings will be too high. And if the humidity in the case is too low the strings will be too low.
One of my guitars likes a fairly humid case. In other words, if I keep the humidity in the case about 60 percent + or - 5 percent, it is a nice guitar to play action wise.
Another likes 47 percent + or - 5 percent.
The more expensive radio linked humidistat is nicer because you do not have to open the case to read it, and you can add up to a total of 3 units for $20 each additional unit.
If you keep the humidity in the case constant the guitar will not have problems. The neck will not change in curve, the strings will stay at the same height, the frets will not stick out from the side of the neck, and the top and back will not crack.
Chose a guitar by how it feels to you and how it plays and sounds. If a guitar looks real promising but the strings are very dull / oxidized, kind of like a dirty brass, not shiny, do not judge that guitar until you hear or play it with new strings on it.
Check with your local Community College to see if they have any evening adult cources to learn basic guitar playing. It is a good value for the amount of lessons you will get verses price, and it is a well organized orderly presentation.
Good Luck.
