Go with the 0W20!! Same price, no reason not to!
I think its odd that BITOG members would think that:
5W20 is as thin as 0W20 at -40f, no data sheets show that to be true.
At very cold temperatures:
0W20 is thinner than 5W20
5W30 is thinner than 10W30
10W30 is thinnner than 20W50
Etc.
The advantage is about 9 degrees f per cold viscosity
specs, which translates directly to cranking and starting ability.
Looking at lots of published data, for a constant CCS number:
20WXX -4 f
15WXX -13F
10WXX -21f
5WXX - 30F
0WXX -40F (Synthetics also fall to the better end of the variation)
Extensive testing published years ago by GM also showed that these may be the minimum starting temperatures for a typical engine. Interestingly, the BMW that I bought new and kept "forever" almost exactly matched these starting predictions in winter. Bought during the "thick oil" days, it was very poor at winter starting, but the thinner oils made it bulletproof!!
I seen no reason in very cold temperatures to run 5W20 if 0W20 is available
