good cold weather oil
Originally Posted By: MNgopher
You are already using a synthetic 5w20. More than adequate for anything we will likely run into. I use conventional 5w30 in all my rigs (except my new to me 04 F150 that gets 5w20), and they survive fine, even parked outside with no block heater. Sure, they are a little balky at -25 or so, but that is only every now and then and few minutes warming up and they are fine. Modern fuel injection makes cold starting much simpler than it was before (Thank goodness!)
If it makes you feel better, then 0w20 would be fine, but I certainly wouldn't beat myself up over it.
What he said...
Most people up here are using 5W30 conventional and their vehicles start just fine.
I'd definitely switch to a 0W-20 oil as they are MUCH lighter than a typical 5W-20 like Pennzoil Platinum.
For example the Toyota, Honda and Castrol Edge 0W-20's will be 40% lighter at 0C and progressive more so as the temp's drop. Even at room temp' these oils are 25% lighter than Pennzoil Platinum 5W-20.
Now for extreme cold temp's; -40 degrees, PAO based Mobil 1 0W-20 is the champ with a MRV of 10,400cP.
