This is in the kia. I have no real complaints on the factory 6 speaker setup... its about 200 watts in laboratory conditions, probably much less in every day life
.. It sounds good most of the time... but on certain songs / frequencies its as if the speakers are "worn" or "loose" as in they move more than they should. I have the bass at -3 (-10 to +10 values) and the mirrors are just about useless if over 23 (out of 35) on volume level.
Anyways I want to keep the factory headunit just for the looks and functionality.... for time being. (I am thinking about a full touch screen navi setup down road).
I am looking for (4) 6.5 inch speakers that can run off the factory watts (and aftermarket headunit down road) and sound better then the worn out paper ones currently in the car.. I never max out the radio even at highway speeds with the windows down so "volume" is not a issue.
What's your recommendations on a decent 6.5 inch speaker that does not require hundreds of watts to sound good? Im flexible on price, but we will say $150 cap per pair. I also don't know about mounting depth, but when I had the door panel off there is some room to work with..
Thank you for the recommendations.
