Over the past year I've had some bad experiences from non dealership places.
1. NTB lied about the struts on my car and my wife's car. They also lied and said the power steering fluid was burnt in her car. All of these things I had re-evaluated and it's not true at all.
2. Local mechanic told me he was using OEM calipers. Never did. Put cheap calipers on that rusted after 3 months.
3. Friend went to some Iffy Lube place. Filter was loose and leaked oil until engine was bone dry.
4. PepBoys put the wrong size tires on my friend's car, almost causing her to get into an accident.
5. Another quick lube place put the wrong MTF in the Honda.
6. Another quick lube place put in that ATF mix in the Mazda, which technically is not the correct fluid.
I take some responsibility for not checking on these guys, but I shouldn't have too. Back to the dealer and using OEM parts.
In addition, I've found that after market brake pads and rotors are just not as good.
